11-01-2008
If you do not have a name - but the boat has sail numbers - use the sail numbers. Otherwise - use "Unmarked Sailing Vessel - [make, length, color (if non white)]"...(preferred in your case).
The other option is just use "S/V John (or Jane) Doe"..synonymic with "no name"...
the whole purpose of using a name or something to identify a vessel is so that one can be hailed or acknowledged by either party.
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
