Blogs
Go Back   SailNet Community > General Interest Forums > Seamanship
User Name
Old 08-05-2002
cmj cmj is offline
cmj is on a distinguished road
Spin pole downhaul block placement
Hi all,
A co-owner on our 27ft racer wants to move the spin pole downhaul block back to the base of the mast from its usual position halfway between the mast and forestay, as we''ve recently broken the pole''s wire bridles due to cranking the pole back without releasing the downhaul (oops).
Moving the block back to the base of the mast seems dangerous to me as it''ll be under the bowman''s feet during jibes, and the downward tension on the bridles won''t be balanced. I''ve also never seen this on other boats.
Can anyone advise as to whether this is safe / a good idea?
Old 08-09-2002
fer@fer's Avatar
fer@fer fer@fer is offline
fer@fer is on a distinguished road
I greee with you. Moving the spin pole downhaul block back to the base of the mast from its current position is not a good idea. You gave the correct reasons why not.
You might also wan''t to post this question to Brion''s Toss spartalk at http://www.briontoss.com/
and also reviewing he''s Archive looking for a similar question.
Fernando
Old 08-12-2002
mikehoyt mikehoyt is offline
mikehoyt is on a distinguished road
Isnt the placement of the downhaul block used to hold the pole in place? It is my belief that the downhaul, guy an uphaul hold the pole in position. Without the proper placement of the block the pole would probably move all over the place.
Regards,
Mike
Sponsored Ad
Old 09-14-2002
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Moderator
Jeff_H will become famous soon enough
There are two thoughts on that, small boats tend to use a pole downhaul that is located at the base of the mast and is on the axis of the pole eye. This permits quick adjustments of the pole with trimming the downhaul and easier end for end jibes. Larger boats use a foreguy which is mounted below the bridle (or pole end) and which stabilizes the position of the pole, allows for easier dip pole jibes but which requires trimming when the guy is trimmed.
Display Modes
vB code is On
Double Spinn Sheets davidk Racing 25 03-07-2007 02:22 PM
Spin pole downhaul block placement cmj General Discussion (sailing related) 3 11-19-2002 06:13 PM
Spin pole downhaul block placement cmj Racing 1 08-15-2002 01:38 PM
Spin pole downhaul block placement cmj Gear & Maintenance 0 08-05-2002 05:39 AM
looking for good Carbon spin pole verticalmoves Racing 1 02-01-2002 05:47 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
