02-18-2009
If your 23 footer has an outboard motor, you won't be able to get a bigger, inboard powered boat with a fixed prop in and out of a slip without learning how to maneuver an inboard boat under power. You can turn an outboard motor and direct it's thrust, and that makes it easy to learn to use, but, you can't do that with a fixed prop inboard.
I've chartered many times, and, when the company was checking me out, I've never had a charter company ask me to demonstrate my sailing competence. What they want to know is whether you can maneuver the boat around the docks, because that's where any damage is most likely to happen. You should at least be able to rotate a fixed prop inboard boat in close quarters, and you should be able to get it in and out of a slip. If you can't demonstrate the ability to do so, I seriously doubt that the charter company will let you take the boat on your own, without a hired captain. Needless to say, a hired captain on board might put a damper on honeymoon activities. Considering the importance of the occasion of your honeymoon and your inexperience in handling a fixed prop inboard boat, I would suggest you learn how to maneuver such a boat under power before you charter one. Operating an inboard boat isn't something you can easily teach yourself.
Chapman's book on Seamanship has a section that explains how to do it. Read it, and if you understand it, and think you can do it successfully the first time without practice, go for it. Most people find it helpful to have someone demonstrate how to maneuver such a boat. I'm not so confident that you can do it. Most people can't do it. Some people have operated boats for years and still aren't very proficient at it.
If, however, your 23 footer is inboard powered, and if you can maneuver it reasonably proficiently under power, then the larger size of the charter boat shouldn't be a particular concern. Just take it slow and easy around the docks.
