05-26-2009
Bombay Clipper
I am fairly confident that most charter companies will cover mooring and anchoring procedures. Boasun's procedure will work great but may differ from what your charter company requires.
Another method that seems to be preferred by charter companies in the VI is to have a line with the bitter end on your starboard cleat (your choice), approach so the starboard hull is on line with the mooring, slow to a near stop right on the ball, pick up the mooring pennant, run your line through the eye and back to the same cleat making it as short as possible so that you can easily reach it from the boat. If you haven't already, you can leisurely run another line from your port cleat over in front of the boat to the starboard side and loop it through the mooring penant and then back to the port side. Now you can slowly let out some line from the starboard side until your two lines are about the same length creating a penant with two seperate lines.
You should have an anchor bridle already on the boat ready to go.
