12-18-2006
Originally Posted by Newport41
We have the largest below deck hydrolic autopilot we could find and we carry a spare drive unit and I still wouldn't rely on it offshore.
I'm looking at this scenario. I have a 41-foot full keel steel pilothouse cutter of 24,000 lbs. light load (no water, no cargo, full diesel tanks) with Marol hydraulic rotary actuator driving a ram that is attached to a transom hung rudder. This rudder also has a tiller head and a proper tiller. There are two steering stations, a wheel in the pilothouse and a small (30 inch) wheel in a "well" about 15 inches deep on the aft deck. The actuator is 19.3 cu. in. capacity and works well. I am leaning toward a ComNav Commander autopilot with a somewhat larger (25 cu. in) actuator. I want to pair this with a largely separate windvane and tiller arrangement for offshore. I figure to motor under autopilot, or sail coastal with autopilot, but to passagemake with windvane for reasons of power and wear. What size actuator would you recommend and what type of windvane would you favour?
What is the best method of hooking a windvane into a hydraulically driven autopilot? I would have thought the simplest method would be to avoid it completely and to just rig blocks and line on the tiller arm and watch for chafe...but I like to hear people's thoughts.
