09-22-2009
Moderator
Originally Posted by stpetersburgsailor
for instance, there is many daybeacons/markers with red & green
but then the channel has two entrances....
so how do you know which one is returning or leaving?
If I understand you correctly, these red/green markers are not all that unusual.
They are placed where the channels split or converge (depending which direction you're heading.)
If you are heading upstream, and encounter a red/green where the channel splits, and you intend to take the right hand channel, then the marker is a "green" and kept on your port side. If you plan to take the left hand channel, then the marker is a "red" and kept to starboard.
Is this the situation you are describing, or am I missing something?
