Go Back   SailNet Community > General Interest Forums > Seamanship
  #21 (permalink)
Old 10-15-2009
Jeff_H's Avatar
Super Moderator
Sailormon and SD
I see your points. On pre 1970's era boats, the winches were often mounted on pedestals that were bolted into the coaming giving them great longitudinal strength but not much transverse strength. How could I forget. That said, I am still not sure that the transverse load is all that much greater than tailing from abeam of the winch. Then again, as I think about this, when I started sailing, tailers were often asked to tail from aft of the winch so as to not spring the coaming.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
  #22 (permalink)
Old 10-15-2009
GeorgeB is on a distinguished road
Something you might want to consider is installing a pair of foot blocks (or a turning block on an eye strap) aft of your winches to give you a fairlead from that angle. That way, you can cross-sheet without using the other (leeward) winch as a turning block. This will give you two advantages, first, it will eliminate the extra friction and two, it will free up the lazy winch so you can prefeed the lazy sheet on it, setting up for your next tack. This is a time saver if your are doing a lot of tacks and is most helpful if you are forced into doing an emergency tack for any reason.
The Cruising Cockpit Sue & Larry Buying a Boat Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Gear and Maintenance Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Cruising Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Her Sailnet Articles 0 07-08-2003 08:00 PM
Sailing Basics Steve Colgate Her Sailnet Articles 0 03-09-2003 07:00 PM
