10-21-2009
baDumbumbum
Since the 3rd cringle is so high and you don't want a lot of heavy line up there, flopping around and chafing the sail or screwing up leech shape ... would you consider using a very light, slick, and small-diameter high-tech line for the purpose? That is, instead of using a thin messenger line to pull a fat line thru, why not use super-strong 3/16" spectra or Vectran and call it good? Tensile strength of 3800 and 5500 lbs, respectively. It won't weigh or chafe any more than the messenger line, and you can dispense with the whole switcheroo -- which, as others have noted, is not the kind of fine work you want to be doing in 3-reef conditions.
It would leave a long fall to deal with, but you gotta stow the messenger line anyhow. Whip a dozen coils on it, tie it off, and stuff it deep into the flaked mainsail.  Front cringle could use a second line or a tack hook, right?
Re: trysail vs. third reef. Understand the concern. Unless you are using a babystay that coincides with your lowered tack (where the leech tension acts like a backstay of sorts), there could be mast pumping. But doesn't a trysail have the same problem? Most I have seen share the main mast track or utilize a second luff groove, & they only hoist part way.
Buccaneer18, Grainnia
SJ21, Diarmuid
