10-14-2009
Originally Posted by sailingfool
I assume your limitation is that the boom endcap only provides for two reefing lines (otherwise you would run a permanent third for the circumstances where you might anticipate its use)?
You could use some small stuff to tie a messenger line line from the second reef clew thru the third and back to itself, and leave it permanently rove. When you need the third reef, attach one end of the messenger line with a rolling hitch to the bitter end of the first reefing line, haul the reefing line up through the third clew, then back down around the boom and secure it to itself with a bowline. You are ready to reef, again.
Such a solution is not a bad idea, as a third reefing line is a very long piece of line to be tucked away when the main is down, I would not keep it rove through the clew, just in the boom.
And this is exactly the technique I've read about elsewhere. They recommended a type of splice in the messenger that would allow you to tuck the reef line through the messenger to thread it through the clew and back down to you. Not sure where I saw the article unfortunately.
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
