10-24-2009
Ex Member
Originally Posted by L124C
We were in light air, but we went from a deep run, doing just over two knots (over ground), to Wing on Wing, doing just over 4. Why do I see racing boats using spinnakers in light air? Are they not maximizing sail area like I am Wing on Wing?
Well, winged means you're a few degrees either side of DDW... slow! (unless it's blowing 20+)
You can also run DDW with a kite up, and yeah... basically the whole kite is on the weather side of the forestay so I guess it'd be "winged", but we don't do that in less than about 15, it's quicker to gybe through a series of deep reaches. Basically if you're winged out you're in full drag mode getting pushed by the wind rather than pulled (like every other point of sail). Sails are much more efficient operating in lift mode. However, assuming you don't have a spinnaker yeah winged might work best for you for getting downwind since it's very hard to keep a genoa drawing well on a really deep reach since the sheeting angles are all wrong at that point - can't really have the headsail sheeted to a point 20' off your beam. Never a simple answer is it?
Oh, and the goose dies
