Go Back   SailNet Community > General Interest Forums > Seamanship
Old 11-19-2009
C22Reflections is on a distinguished road
Reducing sail on Catalina 320 with roller furling main
I own a 1986 Catalina 22 with conventional slugs on the main and hanks on the jib. I've recently been sailing on a friend's new Catalina 320 with roller furling main and headsail, and am unfamiliar with the ability to reduce sail with the rolling systems, would like to be a more useful crew when sailing shorthanded and am asking for comments.
We sail on Port Philip in Melbourne Australia, which is shallow and wide, and recently found ourselves out in winds gusting to 25 knots near a lee shore, giving us a big, short chop, and beating to windward.
The headsail we're carrying on the 320 is reasonably small and factory fitted (I think a high cut 130). There is some reluctance by the owner to roll in the sail to reef, as it may stretch the sail and affect sail shape, so it seems to be either all out or all in. Furling is done by sailing just off the wind so the sail has some tension on it, rather than have it flog while rolling in. Any views on rolling in to reef? Is it bad for the sail?
The main rolls into the mast which is foreign to me. Clearly this is meant to be reefed, simply by rolling in to whatever position is desired. Again, I suspect this is done by sailing just off the wind so the sail has come tension on it rather than heading directly into the wind. Is this your view? Anything else I should know about the roller furling main system?
Finally, I understand that with the masthead rig we are better off beating into 25 knots and a short chop on a full headsail and reefing the main, and taking the traveller to leeward. This gives us speed off the headsail and pointing ability with the reefed main, and with the traveller down reducing the heeling angle. Makes sense to you?
Old 11-20-2009
christyleigh's Avatar
christyleigh is on a distinguished road
The owner is right about reefing affecting sail sail shape, but not because it is stretched, but because the genoa has a built in 'belly' that gets extra baggy around the middle of the sail and affects shape when reefed. On my previous C320 and my current Nauticat I have a 'luff pad' to help with the shape issue down to about 100%. I had a Foam Luff Padd added to the C320 and my current North Sails genoa uses rope to pad part of the luff just because that's the way North does it.
The key to furling the genoa is tension on the furling line and genoa sheet (depending on which way you are going - in or out) whether it's for a partial or full furl. I do most of the sail handling myself so it's one hand on the sheet, the other hand on the furling line, with Auto steering the boat. While as with most things it's easier with 2 people, but when I'm doing it myself I know exactly how much tension to put on the furling line to fight the pulling out of the sheet when un-furling and the opposite when furling....... instead of yelling .... slack.... tension...(I easily overpower her so I have to be careful) over and over again to my wife
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
The Basics of Reefing Mark Matthews Learning to Sail Articles 0 03-29-2004 07:00 PM
The Basics of Reefing Mark Matthews Seamanship Articles 0 03-29-2004 07:00 PM
Using Riding Sails John Kretschmer Gear and Maintenance Articles 0 02-26-2002 07:00 PM
Sail Trim Steve Colgate Learning to Sail Articles 0 05-10-2000 08:00 PM
