12-11-2009
ASA and PSIA Instructor
Originally Posted by BELLATRIX1965
OK - but won't the cheek block (the reefing line runs FWD to AFT on the side of the boom, through the cheek block, up through the reef clew (cringle), and then back down to the boom) keep the reef line lead AFT, regardless of the bowline-secured bitter end????? If you do what sailingfool prescribes, the bitter end will form a "choker" too, which will help??
The cheek block is obviously AFT of the reef clew position. Thanks again for all the input, by the way!!
I've found securing the bitter end to the reefing line, around the boom, to permit trimming as flat a reef as you wish...the line first pulls the clew down, then continues to pull aft. The is the termination method I've seen in various manuals, including the attached Catalina instruction.
As to locating any objects on the side of a boom, I personally have been hit by an angry boom only once, but by a flat section, producing some messy bruising. If I had been hit by the edge of a cheek block or a padeye, it would have been a whole different experience.
You can obviously do a more complicated solution that introduces un-necessary danger to a sport that has enough already...your choice.
