I sail wing-on-wing, invariably, just about everytime I head out in the summer. I'm in Charleston on the Ashley River and there is a dead spot as far as wind goes between the Coast Guard Base and Battery Park ... so, unfortunately, I have to wing-on-wing in light winds making minimal way. It sure looks cool though. It's a sloop equivalent to setting the royal sails
I just threw together a crude video of our SJ21 deep reaching last weekend. It was more instructive before YouTube's compression got at it, but there are still some details worth noting.
TWA was about 160 degrees, tucked behind my left ear. You can see the jib clew flutter as the mainsail blankets it. But the jib luff is still drawing as is the main -- just around the 1 minute mark, you can (maybe) see the telltales show apparent wind just behind the beam: the boat is moving almost 4 kts in 8 kts true. I'll take it.
Boom is well out; could afford to go out farther. Jib cars shoved all the way forward; outboard sheeting would be better, since the inboard cars pull the clew in. The lazy sheet is very slack so its weight doesn't pull the clew in still more. I should have eased the halyard/downhaul and outhaul more; the mainsail is too flat for such light winds. (It was blowing 15-18 earlier.)
Vang is on, but not too hard. Yes, vanging flattens the bottom of the sail slightly -- but not vanging permits the upper half to twist off, luff, and spill its air. That's where the good breeze is, and you want to snag it. Don't vang so hard you flex the boom, because that will pull draft out of the sail bottom. But if you bag out the foot and then fail to vang, all your lovely captured wind is gonna slide right up the sail and spill off the twisted leech. Vang just enuf to bring that top batten back into line. On deep headings -- once you are confident the aft portion of the sail is no longer lifting -- the leech line can be used to cup the fabric still farther, giving more drag power. (Make sure to ease it when heading back upwind, tho, or it will spoil the exiting air.)
Subtle, subtle technique: we can spend our whole lives learning to sail downwind well. I intend to! And preferred tactics will change according to boat type. The SJ21 is a light, flat-bottomed sloop that easily gets to hull speed in modest winds, even on working sails. On a heavier cruiser, you would probably sail deeper angles and pile on sail area.
That's great, Bob, thanks. I snagged an extra day off tomorrow and am anxious to try some of these suggestions. I wish there was actually going to be some wind in the forecast, but oh well.
If you do another video my vote is for leaving the original audio track. ;-)
Just a further point I don't think I've seen mentioned. I think it also depends on the boat? Different boats do better or worse on different points of sail on account of their design characteristics. So if the boat is handling poorly on a particular point of sail it may not even be anything to do with your skills.
I liked sailing wing on wing the one chance I've gotten to do it (I'm new), but it sure made it hard to see where I was going!
If you think that's fun, wait until you add a spinnaker to your sail locker.
I called in sick to work, shanghai'd my kids into crewing for me and gybe'd our way home from Thomas Point lighthouse. I'm ready to try it in a stronger breeze.
Lydanynom-
How'd all these suggestions work out for you? Have you tried your BFS Global Regatta course yet?
S/V Old Shoes
1973 Pearson 30 #255
