09-07-2010
To correct a chart; you start with the earliest LNM and work forward to the latest...
This is why we keep chart cards on all of the charts carried on board. As the LNMs come aboard, You registared each LNM on the CD and you only need to correct the charts you are using. But when you adventure out into other areas, all you need to do is break out the chart cards and see which LNMs you need to correct that particular chart.
1600 Ton Master, 2nd Mate Unlimited Tonnage
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Maritime Instructor To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
S/V Rapture
