10-03-2010
Originally Posted by mccary
Durring the recent Sailnet Photo Op in Annapolis (last Sunday) I was on the rt 450 bridge and had my handheld Standard Horizon 851 with me. The boats were about ¼-½ mile above & below the bridge. I was easily heard on LOW power by all (no one complained). The high power on that unit is 6 watts and has 1W, 2.5W, 5W settings.
Hi Mate,
Its line of sight, position, height of antenna, power and radio quality.
If, you were on a bridge, what altitude is the antenna? It should transmit a mile or so. Many fixed sets onboard have the antenna up the mast for greater range. Whip antennas should be at the stern and also at a small angle off the vertical to clear interferance and impedance reasons.
Although this has nothing to do with your comments, weather patterns also have an impact on VHF reception and transmision. A trough can cause 'skip'. You may not be able to communicate with someone a mile away, but can hear transmissions up to 300nm away as if they were next door!
Casio's problem is probably the norm, as in addition to the low altitude (prob 4'), he has the interupted line of sight and also other electrical impedance caused by instruments and mast/ stays etc.
Anyway, I reckon you should have been on the water with them
