Go Back   SailNet Community > General Interest Forums > Seamanship
Old 09-29-2010
5hortBu5's Avatar
5hortBu5 is on a distinguished road
Running downwind in a Javelin
Hi Folks,
This past weekend, I took a short daysail on the Delaware River. a good portion of the sail was downwind, and as a result of some of the decisions I made at the time, I now have a sail trim question.
On the Javelin, there is no backstay. Instead, the spreaders are raked astern and the shrouds are mounted well astern of the mast step, acting as shrouds *and* backstay. This obviously limits the swing of the boom.
While running wing-and-wing, I sheeted the main to a point that it didn't lay too hard on the spreaders or the shrouds, but that got the back of the sail uncomfortably close to the wind at times, and I did have to deal with one accidental jibe.
So, with my standing rigging's restriction on boom position, would I be better off jibing my way downwind in a series of very broad reaches, or is not-quite-boom-abeam wing-and-wing an okay trim configuration?
Old 09-29-2010
nolatom will become famous soon enough
you mean the Oday Javelin 14 I guess? (not the Tripp Seafarer 38 with a backstay)?
whichever Javelin it is, if you can't get the main out far enough because of shrouds or spreaders, then going to more of a broad reach would be preferable, I'd think. that way you wouldn't have to concentrate so hard on avoiding the jibe you're always on the verge of on a run, and can enjoy the scenery more. the distance you give away would be almost made up for in increased speed, at least in light and moderate air.
Old 09-29-2010
Generally, going dead downwind is the slowest point of sail for most boats.
"Tacking" downwind via a series of broad reaches is probably faster and in many ways safer, since you're far less likely to experience an unexpected gybe.
O'Day Javelin 14 sailingdog Learning to Sail 8 07-24-2008 09:28 PM
Running downwind at high speed, how to turn away? Lancer28 Learning to Sail 69 10-04-2007 12:46 PM
Used Javelin Parts mmusen O'Day 0 07-08-2006 10:02 PM
oday javelin sailingforever O'Day 1 04-16-2006 09:01 PM
O''Day Javelin ID jclarkb General Discussion (sailing related) 1 10-16-2001 03:58 PM
