02-18-2011
This is simply giving you a starting point for your sheet lead positions, you could do it on a profile drawing of your sailplan.
Draw a line from the midpoint of the forestay (or the luff of the sail if it's not full hoist) through the point of the clew and carry on to the deck. Where the line hits the deck is where the car should be placed for starters.
Then, while sailing you'd move it fore and aft as required to get the ALL telltales to 'break' at the same moment. If the upper set stalls/breaks first, move car fwd and try again (and vice versa, of course) Ultimately when you pinch up towards a luffing heading all the telltales should react at the same time.
As you say, though, the clew is not always in the same spot so bearing off to a close or beam reach will required readjustment of the position - that's why race boats and hi perf cruisers have the ability to adjust these leads from the cockpit, under load.
1984 Fast/Nicholson 345
