Go Back   SailNet Community > General Interest Forums > Seamanship
  #11
Old 04-29-2011
puddinlegs is on a distinguished road
bowline is easy to tie and break quickly. J-lock type shackles are nice, but pricey.
Tylaska Marine Hardware - Mystic, CT
Yes, getting hit by one hurts, and they can ding the mast when tacking.
Going up the rig, I like a climbers figure 8 a la here:
Rock Climbing Knots: Figure Eight
(top diagram)
  #12
Old 04-29-2011
glmark is on a distinguished road
Maybe I just don't understand the response, but how does the snap shackle get attached to the line if not with a knot. (sorry)
  #13
Old 04-29-2011
SVPrairieRose's Avatar
SVPrairieRose is on a distinguished road
A tight eye splice or a whipping, but just because a product exists doesn't mean you must use it. Spray on hair, spray on cheese and shackles on jib sheets.
  #14
Old 04-29-2011
A splice. Whipping alone won't hold much of anything.
  #15
Old 04-29-2011
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Originally Posted by RichH View Post
If removable is important, then add a stainless locking caribiner/shackle.
I don't even want to think about hauling a shackle across on a tack, much less the clew flailing-about with a shackle on it.
No! Absolutely not!
For use of two jib sheets the buntline is far superior to the bowline, just add a few feet to the lines as you'll need to cut off a buntline.
That could get kinda spendy, even with plain ol' Sta Set, doing that once-per-time out, or especially if you're racing and have a changeable head sail system
Originally Posted by MarkofSeaLife View Post
In the 'old days' prior to furling genoas a sailor would forever be switching headsails: Genoa No1, 2 and 3, Jib, Storm Jib. So you had to whip the sheets off fast, and on fast!
The "old days" are still with us, tho it's mostly only racers that do that, these days .
What we have currently is a Tuff Luff system. What I'd like to have on Abracadabra, some day, is the Harken Mk. IV system, which allows one to easily switch between furler and racing foil systems
Jim
  #16
Old 04-30-2011
Zanshin's Avatar
Zanshin is on a distinguished road
I like the idea of making an eye splice on the genoa sheet, then using a modern Dyneema/Spectra soft shackle to attach it to the sail. I've made up the soft shackles already (they are very easy to make yourself, hold incredible loads, and are neither heavy nor as hard as a steel shackle) but need to wait for the right time to splice the sheets - which means when I replace them as splicing used double-braid is very difficult.
  #17
Old 04-30-2011
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
Actually a Seizing is almost as strong as a sweging or a splice.
To seize two lines together is an time honor method of making an eye or finishing off a bitter end to the standing part of a line.
But it takes skill that the average sailboater don't have. It requires either an old time rigger or Boatswain to apply one where it is needed.
I've made and used the seizings many times where a knot, hitch or splice just wouldn't just look right or just won't do. Don't worry the seizing held.
It is an art under some situations you may need to use up to four or more seizings. Usually on stays & shrouds of made old school.
Oh it may look like a whipping, but I asure you it is not a whipping.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
  #18
Old 04-30-2011
pdqaltair's Avatar
pdqaltair is on a distinguished road
And splicing used double braid is not always possible.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
  #19
Old 05-01-2011
scotthenry is on a distinguished road
One method I like is to use a toggle-and-becket for a changeable jib sheet. I first read about it in the old classic book "Shipshape and Bristol Fashion" (page 19 in my copy). It only works with clew eyes and not clew d-rings, was very easy to switch sails. It does rely on good seizings, though...
  #20
Old 05-05-2011
CaptFoolhardy's Avatar
CaptFoolhardy is on a distinguished road
It does, with a very secure but difficult to untie knot such as the buntline hitch. The snap shackle makes it easy to disconnect quickly. I agree with the other posters who have pointed this out though that the potential for damage and injury far outweighs this advantage.
You may post attachments
You may edit your posts
Frayed Knot Coldwater Gear & Maintenance 10 09-23-2009 10:11 AM
More Knot ??'s offline2004 Gear & Maintenance 4 04-29-2007 09:15 PM
What is the name of that knot...? vissepo Seamanship 37 04-02-2007 03:05 PM
Knot log? Nereus32 General Discussion (sailing related) 1 05-15-2005 06:09 PM
SEO by vBSEO 3.6.1
