07-28-2011
Originally Posted by Hartley18
Just to clear up any confusion that may or may not exist: Perhaps you aren't "making 5 knots of headway" when hove-to, but you will be moving slowly forward and to leeward. This is because, to remain hove-to you have to have steerage way.
Without a flow of water over the rudder, with the action of wind and waves, (most) boats won't stay pointing in the same direction to the wind. Since the whole idea is to find a balance between sailing forward (usually on the main) and being pushed back (usually by the jib), the rudder has to keep the boat pointed at the right angle to the wind.
Well, isn't it often the case that boats will "swing" while hove-to, heading up when they have steerage-way, slowing down, and then bearing off?
s/v Essorant
1972 Catalina 27
