Go Back   SailNet Community > General Interest Forums > Seamanship
  #11 (permalink)
Old 06-16-2011
chris_gee is on a distinguished road
Wouldn't any headstay sag be the same on both tacks?
  #12 (permalink)
Old 06-17-2011
jjablonowski's Avatar
jjablonowski is on a distinguished road
Is the genoa equipped with luff foam? Mayhaps, when partially furled (reefed) without luff foam or luff rope, it's too baggy and thus hard to control.
  #13 (permalink)
Old 06-17-2011
tomandchris is on a distinguished road
Mark,
Not sure what you are sailing, but in any case a 150-160% genoa rolled to 100% is not going to give you any decent sail shape. It will also be very different dependent on point of sail because of the roll.
On SF Bay, in the winds that occur there, you probably need to invest in a smaller headsail. Talk to a sail maker that knows your boat and see what they suggest. It could be even smaller than a 100% dependent on your cruising plans.
  #14 (permalink)
Old 06-19-2011
TropicCat's Avatar
TropicCat is on a distinguished road
No one mentioned to check and see if the genny has a leech line. If so, tighten and see if it stops.
Tropic Cat
  #15 (permalink)
Old 06-19-2011
WDS123 is on a distinguished road
It sounds as if the entire foresail is shaking, nit just the leech, but good call - check the leech line and tension when leech is flapping.
  #16 (permalink)
Old 06-20-2011
MarkSF is on a distinguished road
Thanks, I will check the leech line, and the jib track adjustment. However I figured out the age of my sails, and it's at least 20 years. I'm thinking of getting a new main and jib. Now what size jib is the question.
  #17 (permalink)
Old 06-20-2011
Mark, that is also a question for a good SF area sailmaker that knows the bay. Really depends on what performance you want and what you are willing to do to get it. Also depends on what you want to invest.
Many SFBay sailors have a summer and a winter genoa. Your winds are heavier in the summer and less in the winter on average, and if they don't want to change headsails dependent on the days weather, the summer/winter is a compromise.
A Question for higher clew ? hlmffsailmaker General Discussion (sailing related) 7 05-03-2010 07:50 AM
Higher education sailaway21 Off Topic 34 04-07-2008 10:33 AM
Flapping leach mwrohde Learning to Sail 15 02-27-2007 08:50 AM
Waterline higher tjgault Gear & Maintenance 2 03-29-2005 03:43 PM
jib flapping fast jrwright Gear & Maintenance 4 10-13-2004 06:20 PM
