09-28-2011
Senior Moment Member
Originally Posted by Zanshin
Some ropes are tougher to splice than others, and a doublebraided line that has already been used or put under load can be almost impossible to splice. I found that my big rubber mallet helps a lot, I "tenderize" my line for a bit and then get another millimeter before repeating the process. I have a very thin steel fid to pull the line through, it is thinner than Brion Toss' magic wand and I also thin the core down before pulling it.
Do you know which brand line you are splicing?
I've found that washing the lines in a washing machine will sometimes soften them enough but basically, as Zanshin says, old double braid is not a good bet.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
