Dennis,
Not trying to put too much emphasis on the Sentinal. But it can help and that is a fact that has been used by seaman for centuries. But nothing can fully replace adding more scope or having an all-chain
rode.
But there are a few things you said that are not correct.
"Picture your boat anchored on three to one scope, the wind at fifteen Kts. Your
rode would be streight and tought
from the bow to the
anchor chain. Do you think a twenty Lb. sentinal is going to make a difference? It won''t".
YES it will help, the question is- Is it enough for the conditions and there are too many variable (anchor type, weight, bottom etc). to determine that. But there is most definitely an added benefit. Let me go into some detail with real calculations.
I am not sure you saw or read the website I listed before, but it has actual calculations and an excell spreadsheet that you can download and then input the variables yourself (Depth of water,
rode length, chain length, sentinal positioning, sentinal weight).
It is here for anyone who wants to use it http://www1.iwvisp.com/download/pub/spreadsheet/anchor.xls it takes a little knowledge of using Excell to use it though.
(Having a lot of sag in the
rode reduces shock loads and helps keep the
anchor dug in by reducing the angle between the
rode and
anchor. The
best you can do is an angle of "zero", which exists when the
anchor rode is flat on the bottom, and all the pulling forces are horizontal. As tension increases, it reaches a point where the weight of the
rode is overcome, and the angle becomes positive. Positive angles make the
anchor work harder at keeping set, since the
rode is now pulling up on the
anchor. If the tension continues to increase, the catenary reduces to a straight
line, and eventually the
anchor pulls out.)
Lets assume you are in 15 feet of water and you have 15 feet of 5/16 chain and 30 feet of 5/8 3-strand
rode (3 to 1 scope) (no sentinel)
It would take only 33.816 lbs of force at the boat to *begin* to lift the
anchor rode off the sea floor at the point of attachment to the
anchor shaft (not necesarrily where the
anchor pulls out. But this will be our reference point)
Now lets add a 20lb Sentinel 30 feet down the
rode.
It would take It would take 66.657 lbs of force at the boat to *begin* to lift the
anchor rode off the sea floor. That is 2 times force needed than before. A 100 % increase. It WILL make some difference
Now lets assume you changed to all chain with the same parameters (3-1 scope in 15 feet of water no Sentinal).
Now it would take It would take 54.27 lbs of force at the boat to *begin* to lift the
anchor rode off the sea floor. The reason this is not as high as before with the sentinel is because the heavy weight of the Sentinel in relation to the short amount of added chain (30 feet) was located further down the
rode (30 feet)
Lets assume you are in 15 feet of water and you have 15 feet of 5/16 chain and 75 feet of 5/8 3-strand
rode (6 to 1 scope) (no sentinel)
Now It would take only 95.87 lbs of force at the boat to *begin* to lift the
anchor rode off the sea floor. Almost a 3 times increase (even though only doubling the
rode) .
rode.
It would take It would take 131.38 lbs of force at the boat to *begin* to lift the
anchor rode off the sea floor. That is only a 0.5 times (50%) increase in force needed to *begin* to lift the
Now lets assume you changed to all chain with the same parameters (6-1 scope in 15 feet of water no Sentinal).
Now it would take It would take a whopping 248.34 lbs of force at the boat to *begin* to lift the
anchor rode off the sea floor. The reason this is so high is that now the added weight of the chain overtakes the benefits of the 20lb sentinel .
So what does this all mean? (plagiarized from the aforementioned website)
Select the size of your
anchor based on boat length and weight.
Chose an
anchor type suited for the kind of bottom you expect to encounter.
Use as much scope as practical.
Add 20-30 feet of chain to an all nylon
rode.
Consider placing a Kellet about half way down the
rode.
For the ultimate in holding power, switch to all chain
rode.
Using these techniques to increase
rode sag and improve
anchor performance is only one factor in keeping your boat anchored. Adding a sentinel or some chain
won’t compensate for a fouled
anchor, inadequate scope, failing to set the
anchor properly, or using the wrong size or type of
anchor. Also adding a kellet has bigger influences on a shorter scope. So understand the importance of
rode sag and apply it to your
anchor system, it will improve the holding power of whatever system you chose, and maybe even let you sleep a little easier when anchored in your favorite cove.
Tom
