Go Back   SailNet Community > General Interest Forums > Seamanship
Like Tree3Likes
  #21 (permalink)
Old 10-03-2011
davidpm's Avatar
davidpm is on a distinguished road
Originally Posted by sailingfool View Post
It sounds like if you unfurled half your jib and sailed on a beam reach, you could have finished the trip in a few minutes. In rough water you can make much better progress under sail than motor, especially with an outboard. Sure some rough situations sailing is a doesnt-fit solution, but in yours, it sure sounds like the hands down way to go.
Certainly a good idea. The problem is that the channel is only about 15 yards wide with a rock breakwater on the downwind side.
I suppose what I could have done is to have gone a 10th of a mile beyond the channel and then line up for the channel and see if the boat would track down the lay line with the jib.
There is no way I would experiment like that in the the channel because if something went wrong I would have only seconds before being on the rocks.
I'll try it next time and let you know how it went unless you get to read about it on the news.
  #22 (permalink)
Old 10-03-2011
davidpm's Avatar
Originally Posted by Bene505 View Post
Yes, but that can be tough to do solo when in confined quarters about to dock.
I expect David was being cautions. He's one of the most careful people I've met, from reading accident reports and books (e.g. the Fastnet race gone bad), to preparing ahead of time.
Regards,
Brad
Thanks Brad.
I do tend to push it a little more when I'm solo than when I have crew. The theory is that if something goes wrong and I'm by myself I'm usually only endangering property.
  #23 (permalink)
Old 10-04-2011
AdamLein's Avatar
AdamLein will become famous soon enough
Trying to picture this channel. Is it high on either side? If so, and there's enough depth, hugging the windward shore will shelter your boat from the wind somewhat. Might mean you can head in a straight line. My last marina had high rocky jetties on either side of the channel. You could definitely feel the difference in the force of the wind at high tide and low tide (14 foot tidal exchange).
I've had similar problems motoring in waves with a 9.9 on my C-27. I will never try that again; way safer to sail. However, how were you getting waves in a 15-yard-wide channel with the wind perpendicular to the channel? Were they refracting around a corner or something? In my experience in a narrow channel, even with wind, the water is usually pretty flat.
Got a lat/lon of this channel?
s/v Essorant
1972 Catalina 27
  #24 (permalink)
Old 10-04-2011
davidpm's Avatar
Here is the channel. It is Westbrook in CT.
As you can see there is a lot of open (shallow) water on the right where the wind was coming from.
On the left is a stone man-made breakwater.
I was alone with a tiller with no lock.
I think the sailing on furled jib might have worked. If I can duplicate the situation I'll try it for a couple hundred yards before red 2 so I still have room to bail if It don't work.
Rough couple of days almost didn't make it-duckis.jpg   Rough couple of days almost didn't make it-di2.jpg
  #25 (permalink)
Old 10-05-2011
AdamLein's Avatar
Interesting topography. I can really see how exposed the channel is to the southeast.
Have you considered anchoring inside the Duck Island breakwater?
s/v Essorant
1972 Catalina 27
British Couple Saved Afre 40 Days at Sea wlshor Off Topic 4 02-27-2009 07:29 AM
Can a couple of inches make a big differnce? belanich Sailboat Design and Construction 14 02-14-2008 09:43 PM
Couple to Sail for 1000 Days - WXIA-TV NewsReader News Feeds 1 04-22-2007 01:54 AM
High seas: Rough conditions make for a challenging start to race (Norwalk Advocate) NewsReader News Feeds 0 09-02-2006 05:15 AM
For a couple of days ------- waltward General Discussion (sailing related) 2 10-21-2005 03:16 AM
