12-29-2011
Old as Dirt!
Originally Posted by AdamLein
True, but a river is not very much like a wheel. The latter is rigid while the former flows. With rigid rotation you will get tangential speed proportional to radius, but with a liquid, not necessarily.
A naive application of the Bernoulli principle puts the fast water inside, since the inside of turns is associated with low pressure, which is associated with high speed.
Erosion could indicate fast water on the outside, or it could indicate that water is better at eroding soil that it crashes into than soil that it rushes past, ie. On the high pressure side of the curve.
Adam--
With all due respect, the development of sedimentation banks on the inside of the curves of channels is common knowledge and is explained by the fact that the water flow rate slows (relative to the overall flow rate), reducing agitation within the water column, allowing heavier sediments to settle out and at a progressively faster rate. As this sedimentation continues, to maintain the overall mass flow rate which must be constant from up-stream to down-stream in the channel on either side of a curve, water must shift to the outside of the curve, which is logical intuitively as well as mathematically. To change the direction of the flow, i.e. to curve the water-race, there must be a side force applied to the water flow--e.g. the resistence of the banks on the outside of the curve to resist/counter the water's linear inertia. This hydraulic pressure of course eventually dissolves the outside banks--even if they are solid rock--aided and abetted by the scouring action of the sediment suspended in the water itself, not unlike wet sand-blasting a surface such as a hull's bottom. The foregoing accounts for the meanders of rivers over time which one can easily observe from satellite photos of land forms which reveal the evolution of river beds.
For the mariner, the importance of the foregoing is that the deepest water will generally be on the outside of a curved channel tho' one is also likely to find that if "going with the flow", one is likely to get a faster ride than one migh like or, if opposing the flow, little at all.
Here Homer nods...
