Go Back   SailNet Community > General Interest Forums > Seamanship
Like Tree28Likes
  #1
Old 04-09-2012
andrewoliv is on a distinguished road
Thunderstorm in Chesapeake Bay
Fairly to new to sailing in the Chesapeake. Interested in knowing what other sailors do when they see thunderstorms approaching. I sail out of Herring Bay.
  #2
Old 04-09-2012
But if not...
paperbird is on a distinguished road
As usual, it depends. If you sail long enough on the Bay, you'll get to experience a few of them. A couple notes:
- if anchored somewhere, let out more scope, secure all canvas, stuff on deck, etc. Take note of any boats anchored around you. Think through action plans in case you or others drag.
- if underway, shorten sail, don foul wx gear, harnesses, etc. Take note of other vessels in the area, take careful note of how much searoom you have to maneuver and plan ahead for actions as the wind hits and changes through the storm.
Most t-storms on the Bay are pretty short lived. Only time we got a little concerned was when our dinghy went airborne and started pinwheeling on the painter. Was a little disconcerting. Then the storm passed and the CGG showed up looking for a boat that had called mayday.
BTW - we're at HHN in Herring. Would love to chat more. Will be at the boat this Sat finishing up the stanchion rebed project. :-(
  #3
Old 04-09-2012
johnnyquest37's Avatar
johnnyquest37 is on a distinguished road
Re: Thunderstorm in Chesapeake Bay
My SOP is to furl all sail and start the engine the moment I hear thunder or see lightning. We also put the hand-held VHF and cell phones in the microwave to protect them if we are struck by lightning. If it is clear that I am going to be caught by the storm, I immediately head for the deepest/widest water I can. Once I was halfway through the Solomon's Island entrance when I saw a bolt of lightning on the south side of the Patuxent River. I did an immediate 180 and headed toward the center of the river - was glad I did cause the storm hit us in about five minutes and I could not even make out my bow for a while in the worst of it.
I furl the sail because you have no idea what direction or speed the wind will be under the t-head. I start the engine because 1) the sails are furled and 2) I want the engine running if we are struck by lightning. Electronics in the microwave should be safe from EMP in the event of a lightning strike.
Mark S. and wkupersa like this.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
  #4
Old 04-09-2012
paperbird I am at HHN as well. Painting the bottom up K row on the hard.
  #5
Old 04-09-2012
But if not...
Andre,
Will try to look you up and say hello. If you need a break from the painting, we're on C dock.
I heartily agree with JohnyQuest's advice to head for open water. If you can't get tied up or anchored, then give yourself lots of room to maneuver.
BTW - in the summer, the AM radio can give advance warning. Lightning crackles on the AM band. And if the Orioles are playing, listen to the game. Will give you about 45 mins warning from the time they roll out the tarp to when the squalls hit the Bay. Yes - personal experience on that one. :-)
  #6
Old 04-09-2012
PalmettoSailor will become famous soon enough
If you sail on the Chesapeake you will sooner or later be exposed to a lightning storm. The advice already given is pretty much what I do.
The only thing I can add is to realize that you are not going to be outrunning any TS you can see on your sailboat. If its in sight, you'll just have time to reef or secure the sails and maybe get your foulies on before its on top of you. It can be tempting to try to make it through that narrow entrance channel to a safe harbor, but its more likely you will get caught in high gusty winds, near zero visiblity and high adreniln from the lightning striking around you at the worst possible time. Its much safer (on the Chesapeake) to weather a summer storm in an area where you have room to manuver in any direction the storm dictates. Its also very hard to tell if the storm is going to hit you, which is likely why there are so many tales of sailors waiting too late and getting spanked. Better to take the precautions while you can and if the storm misses you, great go back to what you were doing.
I just moved from HHS to Shipwright and wouldn't be too thrilled about being caught in a TS while in the "slot" running between HHS and HHN. There is a bit of room in there but not a whole lot. I'd rather wait out the storm somewhere further out and make the run in after it had passed.
One thing not mentioned, that I do at anchor is determine a "panic azimith" which is a safe intial direction to point the boat if you have to get going in a hurry in the dark or low visiblity like a heavy downpour. I write it down and leave it at the helm so I know a compass bearing to steer immediately. I also will keep a fender at the bow in case I need to leave the anchor quickly so I can secure the rode to a floating object to retrieve later. Lastly, there have been some achorages where I felt constrained enough to don foulies and sit through a TS in the cockpit with the engine running in case the shifts broke the anchor free.
sneuman, DRFerron, arf145 and 1 others like this.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
  #7
Old 04-09-2012
BubbleheadMd's Avatar
Chastened
BubbleheadMd will become famous soon enough
Send a message via Yahoo to BubbleheadMd
Midlife, there is so much good information in that last paragraph. Things that I will definitely use. Thanks.
S/V Old Shoes
1973 Pearson 30 #255
  #8
Old 04-09-2012
speciald's Avatar
Special Delivery
speciald is on a distinguished road
Send a message via Skype™ to speciald
Coming back from the Caribbean a couple of years ago we experieced the worst weather of the trip just outside the bridge-tunnel atfter sunset. We saw it coming and furled the head sail. We had 2 reefs in the main alone when we were hit by 60+kts in a strong thunderstorm. We keep the main full and tried to get to the edge of the storm but on radar it went from side to side of the Bay. Lightning struck all around us but we were not hit. It waas scary for 15 minutes then went away completely. I only once before experinced a storm like this off the Bermuda banks in mid-summer.
  #9
Old 04-09-2012
cheoah is on a distinguished road
Hi there, I try to do most of my traveling from early morning to mid afternoon when possible, to avoind the ubiquitous afternoon tstorms. I'd much rather ride out a storm at anchor -- you don't have to be at the helm with all that steel in your hands. Getting below is a good idea if you have plenty of sea room, and out of the channel, and use any resources you may have to keep up with your position and insure you're not dragging. Stay alert, watch for thunderclouds forming, and you may have some more time to get in a good place and drop anchor.
If you have to keep going, I recommend the engine like JohnnyQuest. Thunderstorms are quick lived and intense....hardly worth making a big canvas change, and gusts could make your double reefed main and staysail/partially furled jib take your for a ride. I just strike it all and tie it down.
Go through a mental checklist for battening down and you're less likely to run into any problems with afternoon thunderstorms.
Chase
s/v Cheoah, PSC 34
Pamlico Sound, NC
  #10
Old 04-10-2012
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious will become famous soon enough
Well I'll be the voice in the wilderness here. I keep sailing. Reef down heavily and keep going. I like the stability of having sail up. If the wind shifts and stays shifted I adjust sail accordingly. If it keeps moving around as it sometimes does I'm likely to heave to and wait.
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
You may post attachments
You may edit your posts
Sailing in a thunderstorm saurav16 Learning to Sail 38 3 Weeks Ago 01:11 PM
sailing in a thunderstorm evecircleM General Discussion (sailing related) 17 07-23-2012 01:17 PM
Re: bad thunderstorm warnings NewsReader Mass Bay Sailors 0 07-22-2006 12:15 PM
bad thunderstorm warnings NewsReader Mass Bay Sailors 0 07-22-2006 09:16 AM
Severe Thunderstorm Watch until 8 PM NewsReader Mass Bay Sailors 0 07-11-2006 02:15 PM
SEO by vBSEO 3.6.1
