Blogs
Go Back   SailNet Community > General Interest Forums > Seamanship
User Name
Old 01-28-2001
jimhuggins jimhuggins is offline
jimhuggins is on a distinguished road
In Gear
I recently bought my first sail boat with a diesel inboard auxillary engine. The boat is a Pearson 36 with a 30 H.P. Yanmar. After hoisting the sails is the transmission supposed to be left in neutral or in forward gear while sailing? I have reviewed the boats manual and the engine manual and neither one mentions the issue. I have also heard opposing view points from a few other sailors. Is there a right way and if so why.
Old 01-29-2001
bappelbe bappelbe is offline
bappelbe is on a distinguished road
In Gear
Hi
I put it in gear, but this is because I have
a folding prop that tends to "unfold"
otherwise, I am sure it doesn''t matter that
much.
Old 01-29-2001
hamiam hamiam is offline
hamiam is on a distinguished road
In Gear
I am the previous owner of a C&C 30 with a 2GM20 Yanmar engine. I actually does matter; some transmissions are not meant to free wheel. This was the case with my Yanmar. Actually, I believe that they suggested that you put the engine in reverse to lock the shaft. If you don''t have you manual, call a Yanmar dealer. A locked shaft is good both for your engine and for your performance under sail.
Sponsored Ad
Old 01-29-2001
Fran49829 Fran49829 is offline
Fran49829 is on a distinguished road
In Gear
Yes, put it in gear. Reverse is probably best but never let it freewheel.
Old 01-29-2001
navtron navtron is offline
navtron is on a distinguished road
In Gear
Spoke with Yanmar Dealer at 2 Boat Shows.
They both say it is alright to freewheel because the shaft inside spins up the oil.
Old 01-30-2001
In Gear
A freewheeling prop creates more drag that a locked shaft; leave it in gear while you are sailing!
Old 01-30-2001
In Gear
Ive been racing for sometime and have tested with the free wheeling prop and locked. I have found freewheeling gives me more speed....Think about it....a fan in a room and a breeze blowing in the window. If fan free wheels the breeze blows in unobstructed as it turns the fan...with it locked it will prevent breeze from coming in, stops flow.
Old 01-30-2001
In Gear
Depends on the prop. A folding prop will offer less resistance when the shaft is locked. No question about that.
Old 01-30-2001
In Gear
A folding prop definitely has less resistance
Old 01-30-2001
In Gear
As for the fan analogy; aeordynamics and hydrodynamics, while similar, are two very different mediums. I will try to find the article, however, a free wheeling prop does not necessarily offer less resistance than a locked shaft.
Display Modes
vB code is On
Gear case for Universal M30 or Model 5424 diesel engine besodelmar Gear & Maintenance 1 6 Days Ago 07:16 PM
gear maintenance BOOMERROCKY Gear & Maintenance 0 05-23-2003 11:06 AM
Secondhand Gear Wanted in UK BrendanChandler Gear & Maintenance 0 03-08-2002 01:11 AM
Jeanneau Sun Odyssey 37 stern gear tjbassett Gear & Maintenance 0 02-13-2002 10:04 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
