Go Back   SailNet Community > General Interest Forums > Seamanship
Like Tree4Likes
  #21
Old 01-04-2013
arvicola-amphibius is on a distinguished road
Re: Crash jibe buffer
I made a boom brake out of some rope and one of those belaying cleats you can buy in a shop that sell gear for abseiling and mountaineering. It is alloy and shaped like a figure 8 and a good one here in Oz sells for about 30 bucks.
I ditched the boom down haul, ran a line from one chain plate through the belaying device ( sorry I dunno what they are called) which was attached to the boom at the old mounting point for the down haul about 4 feet back from the gooseneck. From there the line runs to a block on the opposite chain plate and back to a cleat on the outboard side of the cockpit coaming.
Simply tension it as required with a winch and cleat it off. It won't prevent a gybe but slows it down significantly. The heavier the line the greater the friction generated. I have found 12mm to be just right.
Because of the attach point fairly close in to the gooseneck, it is probably unsuitable for a boat much bigger than my 30 footer, but so far it has worked a treat.
Geoff54 likes this.
  #22
Old 01-05-2013
Geoff54's Avatar
Geoff54 is on a distinguished road
Very interesting. I had considered something like this using a Big Rescue 8. What size and type of 8 did you use?
  #23
Old 01-05-2013
SimonV's Avatar
Wish I never found SN!
SimonV will become famous soon enough
All sail boats over 30' should be manditorially fitted with a Dutchman boom break, Any boat I own will have one.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location New Caledonia/Vanuatu
DELIVERY SKIPPER
  #24
Old 01-05-2013
Minnewaska will become famous soon enough
I sort of agree. However, our boom is about 7 - 8 ft above the cockpit. You could still rip it off at the gooseneck with an accidental jibe in rough conditions, but you're much less likely to whack someone in the head.
Jeanneau 54DS
  #25
Old 01-05-2013
I made a boom brake out of some rope and one of those belaying cleats you can buy in a shop that sell gear for abseiling and mountaineering. It is alloy and shaped like a figure 8 and a good one here in Oz sells for about 30 bucks.....
Essentially what a Gyb Easy device is, but they sell them for 15 times the cost!! However, does a climbing figure 8 really give enough resistance. There are other belaying devices that might work even better.
Jeanneau 54DS
  #26
Old 01-05-2013
smurphny's Avatar
Over Hill Sailing Club
smurphny is on a distinguished road
Those climbing friction top-rope devices are basically the same principle as the Gyb-Easy device. The difference is that you can adjust the friction of a ladder device by the number of "steps" the line is threaded through. The ladder devices can also be disengaged by simply taking the line off the "post" at the top of the unit. The one I built from 1/2" s.s. rod would probably lift the boat. Although not as light as the cast aluminum commercial brake, it has to be much stronger. With the 12"x 4" plate shaped around the boom stress will be distributed over a much larger area. Wish I had pictures but it's on the boat which is asleep under tarp and snow:-)
  #27
Old 01-05-2013
I no longer have the packaging so do not know the brand name of the unit I purchased. It was almost identical to the Rescue 8 but did not have the 'ears'.
I was concerned that they could snag or allow the line to jump free. However if more friction is needed the Rescue 8 may suit as long as tension can be held or provided you don't mind going forward to add the extra turns. With the standard 8 it can be left permanently rigged and the tension adjusted as desired from the cockpit. For cruising I find that I rarely need to change tension as what suits as a down haul when going to windward still provides enough friction to slow the gybe.
Each boat will be different, depending on how flat the mainsail, the angle of boom to mast etc.
The only time I need to slack it off is when done for the day and hauling in the topping lift.
You may post attachments
You may edit your posts
Bright work buffer Minnewaska Gear & Maintenance 28 4 Weeks Ago 09:30 PM
NONSUCH 22 - Jibe preventer Essemm65 SailNet FAQ's 3 04-10-2012 08:47 PM
jibe preventer jimmd Seamanship 4 08-10-2007 01:00 PM
jibe question saurav16 Learning to Sail 6 06-28-2007 07:49 PM
Perfecting the Jibe-Set Dean Brenner Racing Articles 0 10-30-2003 07:00 PM
SEO by vBSEO 3.6.1
