Malo 45' loses rudder, pulls an All is Lost - Page 2 - SailNet Community
 26Likes
post #11 of 47 Old 07-01-2014
Learning the HARD way...
eherlihy's Avatar
Re: Malo 45' loses rudder, pulls an All is Lost
Med - I don't think that the 120V bilge pump would help much in this situation. I believe that the inefficiency in running the inverter makes a 120V pump inadvisable. I know that the USCG has high velocity (150 GPM) gasoline pumps that they can drop to a stricken vessel. Here are some pix;
My thought was; IF it were possible to drop the spade rudder safely, to do so (it would be on my O'day - but then again, my O'day would NEVER be 500 miles from land) and thereby stop the rudder shaft from damaging the boat further. Once the shaft was away, you would be left with a hole at, or near, the waterline that would now be the top priority. The boat would probably also begin to yaw wildly... Your first priority once the rudder was jettisoned would be to plug the hole with a throwable PFD, a sail, anything...
Therefore; the sequence of events would be to; contact the CG, prepare the evacuation plan, rig the drogue, drop the rudder, plug the hole, contact the CG, and if possible - limp to port.
eherlihy is offline
post #12 of 47 Old 07-01-2014
Group9's Avatar
Has anyone ever experimented with something like this stuff for a hole in a boat away from the dock? Carrying a few cans to use to stop catastrophic leaks. I know it expands and dries really fast and is hard as hell to get off stuff once it is dry.
At the point you were realizing you couldn't stop the water and were going to have to abandon a boat anyway, what could it hurt to try and use a can or two to stop a leak?
(I know this is arm chairing, but I have used this stuff a few times and it is kind of amazing the way it works. I think I'm going to buy a can and do some experiments with it).
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #13 of 47 Old 07-01-2014
Closet Powerboater
MedSailor's Avatar
Originally Posted by knuterikt View Post
How easy do you think it is to just drop the rudder in conditions like that.
Maybe they could have used ropes to stabilize the rudder, but just dropping it..
I expect it would be slightly harder than postulating from my armchair, that's for sure. I was imagining cutting the shaft. I've done that with a 1.5" stainless prop shaft and it isn't easy. You'd also be using 110V tools in close quarters with lots of water. Or finding a lot of motivation while using a hack saw...
I think I like your rope to stabilize the rudder idea better. Depends on the boat though. My formosa didn't have much rudder stock above the bearing, so there wouldn't be enough leverage to do anything useful.
As for the gas powered pumps, as a recovering wooden boat owner, I've eyeballed those for years. True, it is completely independent of other systems, but I don't like the reliability issues of a small gas engine, with varnished up gas, being stored in a salty bilge, firing up when you really need it. Heck, I have enough of a hard time starting my mower after a winter...
The electric ones have less parts to go wrong, though you are dependent on your generator (if you have one) or inverter. My new boat has both, so there is some redundancy there... I wouldn't worry about power inefficiencies though as I expect you'll be running a generator or engine while all this is happening. They make the electric ones pretty big too. Many hundreds of GPM with 2" outlets.
The gas one, if maintained and tested regularly, is a better option, but it also involves another item to scrupulously maintain and test. It involves storing and rotating gas (which I have avoided so far) and is bigger and heavier. Tradeoffs. I like the middle of the road solution of the 110V pump for my boat, but if I were still on a wooden boat (shudder) I would have the gas powered pump for sure.
MedSailor
MedSailor is offline
post #14 of 47 Old 07-01-2014
Closet Powerboater
MedSailor's Avatar
Yes. The second video at about 8:00 is when they test the foam idea. These two videos are required viewing BTW.
https://www.youtube.com/watch?v=bRhcXBtmPQs
https://www.youtube.com/watch?v=eUg3TUmnQBs
MedSailor
Group9 likes this.
post #15 of 47 Old 07-01-2014
(I know this is arm chairing, but I have used this stuff a few times and it is kind of amazing the way it works).
In my Navy days we had exercises where we stopped water leaks.
We did this on a FPB that where holed and put on land but with water supply on the outside so it was quite realistic...
The problem with that stuff is that you must be able to keep it in place while it hardens - else it would be washed away. It could be used together with other techniques.
knuterikt is offline
post #16 of 47 Old 07-01-2014
My experience with gas powered pumps (especially other peoples) has been less than encouraging. The vessel I had in the Beaufort had a large capacity centrifugal pump belt driven from the prop shaft (idler pulley if you don't want to risk losing a finger) Never used it but you never know when dancing with ice. Thane didn't have enough room for a similar setup so I relied on a 2 inch impeller on an electric clutch and a 110 sump pump which has the advantage of being portable .Never used it either but had 3 wt bulkheads and a long strong keel under it all.
Capt Len is offline
post #17 of 47 Old 07-01-2014
Bristol 45.5 - AiniA
When we were in Australia they were selling a dense, putty-like material to stop leaks. I forget the name of it. It looked quite promising but was not cheap. Don't think it would have helped with this boat's problem since the moving rudder post would just push it away. I think one of the problems with a serious leak is that there can be a lot of different situations. Having a hole like on those videos is entirely different from this one at the rudder post. Saying you have a leak strategy for all occasions just does not work.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #18 of 47 Old 07-01-2014
Group9's Avatar
Yeah, we're just hot washing it. The one silver lining to an incident like this, is that it makes you consider what you would do if it happened to you, and gives you the luxury of time, to do it in.
I'm sure these guys have replayed in their head a hundred times and come with several things they wish they had tried, or been prepared to try. I admit the idea of a rudder coming loose and causing this type of damage never occurred to me before this incident. I just figured the worst would be it falling off and having to plug the hole it left and then figuring out how to steer the boat.
Group9 is offline
post #19 of 47 Old 07-01-2014
Closet Powerboater
MedSailor's Avatar
Best to have a big bag of tricks and start using them one at a time, and quickly!!
Something from the medical profession that I keep abord the boat is 3M Scotchcast fiberglass casting tape. Basically, you open the package, dip the roll in water, apply the tape and a couple minutes later you have solid fiberglass. Seems like it could come in handy. For the rudder, you could just pound the whole roll into the hole.
They also make a slightly less rigid casting material that can be cut with EMT shears called "Scotchcast soft cast". For actual casting purposes aboard this would be infinitely preferable because cutting a regular cast off without a specialized saw is difficult, and if the extremity swells, it can die if the cast isn't cut off.
They also market the same stuff to vets, probably much less expensive too. Though the human grade stuff isn't too expensive either....
https://www.youtube.com/watch?v=hnvDLnVDKCw#t=174
Buy them here, split a box with your buddy.
https://www.mooremedical.com/index.c...PID=4159&spx=1
MedSailor
post #20 of 47 Old 07-01-2014
christian.hess's Avatar
nothing like isolated watertight bulkheads and compartments
if I could id apply james baldwins atom site for a lot of these scenarios.
the reality though is most of us just cant or wont do it...its a lot of work, especially on a boat with big systems.
in any case, always sad to see a boat go down....
peace
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
Another Hunter loses it's rudder knothead General Discussion (sailing related) 20 07-11-2014 07:20 AM
Lost my rudder! TheMadchef General Discussion (sailing related) 16 08-31-2013 01:09 PM
Lost Rudder maineman Gear & Maintenance 17 10-11-2009 06:18 PM
lost rudder clifacs General Discussion (sailing related) 2 06-22-2009 07:18 AM
Beneteau loses rudder..boat sinks camaraderie General Discussion (sailing related) 50 06-05-2008 09:45 PM
HTML code is Off
