Malo 45' loses rudder, pulls an All is Lost - Page 4 - SailNet Community
 26Likes
post #31 of 47 Old 07-01-2014
Old enough to know better
Re: Malo 45' loses rudder, pulls an All is Lost
Originally Posted by DRFerron View Post
I'm following this thread because a Malo is going to be our next boat. I read their blog from the beginning, when they started out from Sweden in 2007. They had autopilot problems that delayed their start and had autopilot problems periodically over the next several years.
What I think you're saying (correct me if it's wrong), is that the autopilot forced the rudder to keep functioning even after there may have been a problem with the rudder, so that what might have been a small issue and easy to fix (maybe, maybe not) became what it did because it wasn't fixed and wasn't noticed?
My thought was that as the rudder stock started to break and twist and break the rudder collar and packing gland the auto pilot kept crunching it as it did not know it was doing damage. A person hand steering may have noticed a change in the feed back and take a look before too much damage had been done. A hydraulic ram or even an electric motor with a good bit of leverage can give quite a bit of torque.
Not sure but I don't think a wind vane would have exerted as much pressure. But I don't think they work well in confused seas anyway do they?
miatapaul is offline
post #32 of 47 Old 07-01-2014
Bristol 45.5 - AiniA
I guess it would depend on how confused the seas were. If the boat is actually moving a wind vane should provide the standard feedback to the wheel. If the boat is just sitting there and bobbing (or bouncing) around the vane won't work. If the waves throw the boat really badly of course the vane will turn its maximum until the apparent wind on the vane changes. I would think that a powerful AP would be doing its best to get the boat back on course which of course isn't going to happen if the sails are not providing some drive. I assume these folks turned off the AP as soon as they discovered the problem, but at that point AP, vane, hand steering are not going to do much to help the situation with the lower part of the rudder banging around.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is online now
post #33 of 47 Old 07-03-2014
Once known as Hartley18
Classic30's Avatar
Dock
Of course, TD Wombat Esq. has a Malo - and, in all my years of sailing, I've not been on a better designed or built cruising boat, ever, really, seriously - and I'm a tad surprised he hasn't piped up here yet.
FWIW, I can't see they did anything wrong in this case and think that they certainly would have had a better chance to save the boat if the rudder had simply fallen off - which it, unfortunately, didn't. Certainly, if the '43 is anything like the '39, securing the rudder in any kind of sea would be a very dangerous exercise and probably fruitless also - it's the wrong shape, in the wrong place and with the wrong mountings for any of that.
I will say I don't remember there being a lot of helm 'feel' on TD's Malo (it's not a racing yacht), so it could be tricky for someone who was a guest on board (their guest was apparently on watch when the incident started) to notice anything wrong even if the AP wasn't in control.
I'm starting to appreciate my keel-hung outboard rudder more and more!
Group9 and christian.hess like this.
Classic30 is offline
post #34 of 47 Old 07-03-2014
Group9's Avatar
Yep. Sometimes, things just break, and there's not much you can do about it.
It makes me think of what is referred to as the "Jesus" nut in a helicopter (it holds the main rotor blades on). If it fails, only Jesus is going to save you.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #35 of 47 Old 07-03-2014
The owner of a Malo 41 has chimed in over on CSBB...
Interesting...
Hadn't heard about it, quite a story, I can add to speculation
christian.hess likes this.
JonEisberg is offline
The Following User Says Thank You to JonEisberg For This Useful Post:
MedSailor (07-06-2014)
post #36 of 47 Old 07-03-2014
Classic30's Avatar
Dock
Interesting...
Interesting indeed.. having bits of your boat underwater fall off without notice is pretty scary, really!!
A little armchair-thinking here, but perhaps people setting off on serious cruising adventures would be well advised to go over all possible failure scenarios and other peoples' reported failures and work out back at the dock if there's anything they could do to mitigate it? I know from their books that faulty rudders and rudder-repair-underway is something that both the RKJ and the Hiscocks countenanced - and had to carry out at one point - and it seemed to me that both selected keel-hung outboard rudders for this reason.
...but it's true that you can't cover everything.. and Murphy's Law is no respecter of persons.
post #37 of 47 Old 07-04-2014
christian.hess's Avatar
if thats the way the shoe is attached you can count on vibrations being it...wow
I dont disagree with that method but like bolts and nuts on motorcycle engines and parts especially exterior ones loctite is your friend.
that is a mighy small skeg there too!
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #38 of 47 Old 07-04-2014
tdw
Super Fuzzy Moderator
tdw's Avatar
Oh my. Sorry folks but the Wombet and I are in the process of moving house, ergo my absence. I have couple of thoughts on this, we dropped our rudder out this year cos I thought it felt and sounded a bit odd but will have to wait until we are settled for more detail.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #39 of 47 Old 07-04-2014
tdw
tdw's Avatar
Quick PS ... just read the CSBO post and I'm thinking he is on the money.
― Terry Pratchett.
tdw is offline
post #40 of 47 Old 07-06-2014
Closet Powerboater
MedSailor's Avatar
May I suggest a book? Very good technical breakdowns of the errr... breakdowns that happened in the book. My copy was drowned recently and is a "total loss". Fitting eh?
http://smile.amazon.com/Total-Loss-Collection-First-hand-Accounts/dp/1574091468/ref=smi_www_rcolv2_go_smi?_encoding=UTF8&*Version*=1&*entries*=0
MedSailor
Classic30 likes this.
MedSailor is offline
Another Hunter loses it's rudder knothead General Discussion (sailing related) 20 07-11-2014 07:20 AM
Lost my rudder! TheMadchef General Discussion (sailing related) 16 08-31-2013 01:09 PM
Lost Rudder maineman Gear & Maintenance 17 10-11-2009 06:18 PM
lost rudder clifacs General Discussion (sailing related) 2 06-22-2009 07:18 AM
Beneteau loses rudder..boat sinks camaraderie General Discussion (sailing related) 50 06-05-2008 09:45 PM
HTML code is Off
