Brunswick CG Rescue - SailNet Community
post #1 of 4 Old 2 Weeks Ago Thread Starter
This is IMO a 'legit' rescue vs. Rescue of individuals knowingly going into known (5 days warning) of adverse weather before hand and then asks for help...
http://jacksonville.com/georgia/news...near-brunswick
aa3jy is offline
post #2 of 4 Old 2 Weeks Ago
Re: Brunswick CG Rescue
Well... any rescue is a legit rescue.
And if you look for it you can always find where something wasn't done right in boat handling, planning and/or maintenance which led to the incident.
Taking on water = leak = he hit something, or some fitting let loose and the bilge pump couldn't keep up (if it worked at all)
And here's my pet peeve about boat OEM bilge pumps. They usually can't even keep up with leaving the drain plug out, much less any of the many potential hose failures.
A 3/4 inch hole (common drain plug for a trailer sailer) 1 ft under water can let in almost 500 gph. A "1200 gph" common bilge pump (rated based on essentially zero lift) might not keep up with the restrictions and back pressure of a typical installation.
Turnin Turtle is offline
post #3 of 4 Old 1 Weeks Ago Thread Starter
With proposed CG budget cuts maybe it's time to look at this proposal again...
http://yachtpals.com/rescue-costs-9094
aa3jy is offline
post #4 of 4 Old 1 Week Ago Thread Starter
aa3jy is offline
Brunswick,Ga aa3jy Florida & SE US East Coast 2 1 Week Ago 11:07 AM
SE Ga.- Brunswick Landing Marina aa3jy Florida & SE US East Coast 18 11-25-2016 08:10 PM
Any one here from St. John, New Brunswick, Canada? Giulietta General Discussion (sailing related) 2 11-23-2007 04:16 AM
Has anyone sailed to Abacos from Brunswick GA ? pmills42255 Cruising & Liveaboard Forum 4 06-14-2003 05:46 AM
Brunswick GA to Abacos pmills42255 Cruising & Liveaboard Forum 0 05-14-2003 02:46 AM
HTML code is Off
