SailNet Community - View Single Post - A/C circulation pump problem
post #5 of Old 06-17-2013
SchockT
SchockT's Avatar
Re: A/C circulation pump problem
If you can post a pic of the wiring diagram that you have we can probably be of more help, but without knowing what operating and safety controls are in the system we are just throwing ideas out there.
Start and run capacitors don't fail very often, but when they do, the motor will try to run, but will over heat and cut out on thermal protection built into the windings. I doubt the the capacitors are for the pump, they are more likely for the compressor.
2011 Jeanneau 39i Azura
SchockT is online now
