SailNet Community - View Single Post - A/C circulation pump problem
post #8 of Old 07-26-2013
svHyLyte
Old as Dirt!
svHyLyte's Avatar
Re: A/C circulation pump problem
Originally Posted by BigLew18 View Post
I wanted to reply and thank those who provided helpful input. The problem was in fact in the relay switch. A simple replacement, and then the compressor and circulation pump kicked on.
Thank you again for the help.
Lew-
If your sea water strainer was a blocked and foul as you describe, you'll do you A/C a world of good by disconnecting the raw water lines and back washing the heat exchanger coil with fresh water. If it is an older unit, you might also want to recirculate something like a solution of RydLyme or Barnacle Buster through it for a few hours to remove the scale/crap that builds up in the coils. It will make a real difference in the performance of your unit.
FWIW...
svHyLyte is offline
