SailNet Community - View Single Post - looking for past or present owners of 1970 through 73 cal 27s
post #14 of Old 11-13-2013 Thread Starter
captain jack
captain jack's Avatar
Re: looking for past or present owners of 1970 through 73 cal 27s
Good to see this dialogue.. thanks for helping out, Michael.
Jack you should be able to see if the original prop shaft is in place, it should be visible from inside (I would think) just ahead of the tank. If someone's converted the original inboard engine space to storage it may be buried there. It's also possible someone removed it and glassed it over. If you stick to your electric power/engineless plan you obviously won't need the tank, that will open up more storage when you take it out. Not sure about converting to a holding tank, it would need some modification and large diameter hoses attached somehow..
If all the parts are there it likely is possible to repower with another inboard but probably not worth the cost. Possibly even an electric drive, but again $$$$$.
But it's great to have a resource like Michael.
it most definitely is!
I am going by the boat, today, before I go to teach class. I figured i'd get in some work. I will look, when I am there. thanks for the input. i just never considered that it originally may have had an inboard.
captain jack is offline
