SailNet Community - View Single Post - looking for past or present owners of 1970 through 73 cal 27s
post #19 of Old 11-13-2013
MichaelAngel442
Re: looking for past or present owners of 1970 through 73 cal 27s
I would take everything the marine owner will give you. You can use the sailing paraphernalia you don't use to barter for things you may need. Your boat can accommodate a smaller jib in addition to the main job. You will see the ring on the mast just under the steaming light and you will see the track directly on the deck towards the bow. For the jib, look for a 120 but no more than a 180. We'll talk more about sails later. But, I wanted you to know as you go through the sails available.
MichaelAngel442 is offline
