SailNet Community - View Single Post - looking for past or present owners of 1970 through 73 cal 27s
post #23 of Old 11-13-2013 Thread Starter
captain jack
captain jack's Avatar
Re: looking for past or present owners of 1970 through 73 cal 27s
Originally Posted by MichaelAngel442 View Post
I would take everything the marine owner will give you. You can use the sailing paraphernalia you don't use to barter for things you may need. Your boat can accommodate a smaller jib in addition to the main job. You will see the ring on the mast just under the steaming light and you will see the track directly on the deck towards the bow. For the jib, look for a 120 but no more than a 180. We'll talk more about sails later. But, I wanted you to know as you go through the sails available.
yeah. that's what I was going to do. I figure that, even if I don't have the optimal sails, all the extra sails they are giving me should help acquire what I want.
sail advice would be great, since you know the boat and I don't. not really worried about a spinnaker. I will usually be under crewed and I can always sail wing and wing, if I need. I did notice the different tracks.
what do you think about roller furling jibs? I was thinking I could do a genoa and the main, using the roller furler to reduce the jib area.
captain jack is offline
