SailNet Community - View Single Post - Low buck projects- Let's see 'em!
post #938 of Old 01-07-2014
Ritchard
No more curry buffets
Ritchard's Avatar
Re: Low buck projects- Let's see 'em!
Originally Posted by ericb760 View Post
Attachment 17570
Attachment 17578
Here's my second Low Buck project that I completed recently. When I bought the boat it had smoked plexiglass drop boards that really didn't fit the design of a classic boat. So, I purchased some furniture grade plywood and cut them using the old boards as a template. After sanding, staining, and four coats of marine varinish, at a cost of around $30, I had new drop boards!
Oddly, I did the inverse of that, I made a plexi drop board to allow more light into my old boat. Man, is Plexiglass ever expensive. Yours look great. A word of advice, pay careful attention to the edges of the plywood. If the finish gets worn enough to allow moisture in, your plywood will delaminate. You may want to put a fresh coat on the edges each year. For more protection, you could remove the varnish on the edge and do a coat of epoxy, then cover with varnish. It will then be much more impervious.
Bashing about on Lake Ontario and Beyond
"Sayonara" '91 Beneteau 38S5
Ritchard is offline
