SailNet Community - View Single Post - Painting with 2-part polyurethane
post #6 of Old 03-18-2002
mikehoyt
mikehoyt's Avatar
Another comment about potential problems.
Be very attentive to temperatures and weather forecasts. According to the manufacturer it is OK to apply a bit below the 10 degree celsius (50 F) recommended (maybe 8 deg C) but the dewpoint is a very important factor. Stay at least 4 deg celsius above dewpoint. Biggest problem with lower temps is lessening of gloss and increased cure time.
Temperatures should remain at or above minimum temp for 8 hours after application. If you do all the work and then it rains you could have "fisheyes" (more likely on a horizontal surface) or other problems.
Mike
mikehoyt is offline
