SailNet Community - View Single Post - NKE wind transducer to which wind display via NMEA 0183?
post #4 of Old 01-27-2014
Bert van den Berg
Bert
Re: NKE wind transducer to which wind display via NMEA 0183?
Hi Rupert,
The WSD110 wind display has two NMEA 0183 inputs, one for wind speed, wind angle and air temperature and one for vehicle speed (usually boat speed) so the WSD110 can calculate and display true wind speed and true wind angle if the vehicle is moving. There is also an NMEA 0183 output to output said calculated data.
You can order the WSD110 through the CruzPro distributor in the UK (Marine Energy Solutions Ltd.) but they do not normally stock the WSD110 and will have to order it from New Zealand.
Cheers,
Bert
Bert van den Berg is offline
