SailNet Community - View Single Post - composting toilet-should we do it
post #69 of Old 02-22-2014
davidpm
davidpm's Avatar
Re: composting toilet-should we do it
Originally Posted by hellosailor View Post
wienie, I know the book you mean just can't remember the name of it.
The author did all his research, picked the "separating" head, and then wound up at one point with 2? 4? women crew on the boat. Apparently the head he chose just didn't properly separate the urine stream from women, resulting in a huge wet mess in the "dry" section that promptly slopped out of the bowl when they were heeled.
At least, that was his conclusion.
And not only that he had some crew compliance issues and some of the women refused to use the head the way it was designed.
It was effectively sabotage in that case.
davidpm is offline
