SailNet Community - View Single Post - Atomic Four Enigne Bad Idea?
post #9 of Old 05-18-2007
sailingdog
Gasoline engines, in good shape and properly maintained are perfectly good engines for a boat. While a diesel may add to the re-sale value of a boat, all other things being the same, if the boat you're looking at has an Atomic4 in good shape, it shouldn't be a reason for you to reject the boat.
The points about diesels being heavier, noisier, and more fuel efficient than gasoline engines are all valid. If you're just going out weekending or on short coastal cruises, an Atomic A4 would be fine. If you're crossing oceans and going long-term cruising, a diesel would probably be a beter idea.
sailingdog is offline
