SailNet Community - View Single Post - Wooden rudder n dagger board
post #7 of Old 04-04-2014
christian.hess
christian.hess's Avatar
Re: Wooden rudder n dagger board
quickest way is this:
sand
lay one or two strips of glass for protection...with epoxy, sand, smooth, more epoxy and a couple of coats of varnish
you said quick and thats quick...the layer of glass helps figh the scuffing rudders and daggerboards suffer and honestly for now you can even bypass the varnish coats uf you keep them covered
that or simply varnish..
the epoxy is great cause it resists scuffing better...you can also bypass the glass if you want and go thickened epoxy, sand, more epoxy and so on
varnish is a slow process at least to do it well
fast curing epoxy will get you in the water andyou can deal with cosmetics later
microballoons are great for fairing...btw
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
