SailNet Community - View Single Post - Yanmar 2QM15 Tranny Noise
post #2 of Old 05-05-2014
christian.hess
christian.hess's Avatar
Re: Yanmar 2QM15 Tranny Noise
nope adjust cable
for example atomic 4 are famous for always having that whinning in reverse as the clutch never fully engages and isnt designed to
for your engine though in forward it shouldbe a solid engagement
have a helper move the throttle and shifter while you are donw by the engine
the best way to do this is to actually disengage the cable so you can manually see where engagement has ocurred then adjust cable and mount to desired cable "throw" or range if you will
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
