SailNet Community - View Single Post - Cutless Bearing Sledge Hammer Installation
post #10 of Old 07-05-2014
Maine Sail
Super Moderator
Maine Sail's Avatar
Re: Cutless Bearing Sledge Hammer Installation
Originally Posted by nramsey View Post
I hesitate to name the business as I haven't negotiated the bill (It's in North Vancouver). To be totally honest, I found a greasy piece of 2x4 with 3 or 4 impact marks. I guess when I arrived he'd given up using the board because he certainly wasn't holding it for the last half a dozen swings. The strut appears OK and the bearing is a little mushed but the bronze clears the shaft, so I guess its OK. He made a few scores in the bore of the strut with a sawzall, when he took it out, but they weren't deep.
I've asked for a bill to date for removing the prop shaft and replacing the cutless bearing. They were hired to replace the PSS seal but couldn't get the retaining screws out of the ring. They cut the shaft in 3 to remove it because the shaft won't clear the rudder. That's understandable but anyone working professionally on boats should know how to drill stainless.
Then he spent some time trying to remove the radial drive wheel through pin. He twisted the head off and didn't agree that an impact driver would have had a better chance of breaking it loose.
After seeing that he didn't know enough to use cutting oil and low speed to drill stainless, I bought an angle drill and drilled it out myself. Awkward angle and location meant it took an old fart like me quite a while.
He kept trying to figure out how to put the new shaft in without dropping the rudder out all the way. Looking at it, it was obvious he was wasting time so I suggested lifting the boat to remove it. That was done and the new shaft went in far enough to drop the boat back down. He even had trouble pushing the shaft in because he didn't lubricate the bearing. After he stomped off I put some liquid hand soap on it and pushed the shaft the rest of the way in.
I'll put the new seal in tomorrow and reassemble the steering on Sunday so they won't p!ss me off any more.
Time to find a new yard.. This guy is not qualified to peel an apple.....
Chances are you now also have:
*An improper fit for the coupling to the shaft = Dangerous and vibration causing
*Lack proper fitting and facing of shaft coupling = Dangerous and vibration causing
*Lack a properly fitted prop = Can also be dangerous and cause vibration
*Likely have PSS set screws that have been "snugged" more than once = Dangerous
______
-Maine Sail / CS-36T
Maine Sail is offline
The Following User Says Thank You to Maine Sail For This Useful Post:
nramsey (07-05-2014)
