SailNet Community - View Single Post - CS33 electrical panel(s)
post #6 of Old 11-27-2017
albrazzi
al brazzi
Re: CS33 electrical panel(s)
I have a CS 30 1987 and at the least you should check all the spades and replace the loose ones, and the ones the wire just pulls out of, probably a third of mine fit this description. Replacing everything is always best, wire included maybe the panel as well. My panel is good for many more years, if I did any major work I would add a sub panel at the Nav station for all the radio and sound system needs. My system is pretty simple but there are grey water pumps, water heater (110V). I will note I removed the raw water loop for the water heater I just didn't like the odds of taking on water in a failure mode and it didn't heat the water well at all.
albrazzi is offline
