SailNet Community - View Single Post - Automatic bilge pump current requirements
post #11 of Old 12-03-2017
Minnewaska
Re: Automatic bilge pump current requirements
Originally Posted by JimsCAL View Post
I installed a Johnson Ultima switch a few years ago. Has worked fine. I like that it is completely sealed with no moving parts. And with an external switch, you can easily test it and wire it up for manual as well as automatic operation.
https://www.defender.com/product3.js...6131&id=344412
Those seem to make all the sense in the world, but I had one of them fail too. Also the Whale version of it. One of the two actually has the wires exit beneath the level of the water that activates the switch, so the water tight seal is being tested 24/7. I assume that's what failed. In any event, it stopped working.
Jeanneau 54DS
Minnewaska is offline
