SailNet Community - View Single Post - For Pete's sake! I just want a speed transducer!
post #29 of Old 03-27-2018
colemj
colemj's Avatar
Re: For Pete's sake! I just want a speed transducer!
If you don't want to replace the thru-hull fitting then you'll really need to know what is on the label/tag at the transducer end of the cable in terms of model/part #.
If he wants a transducer that directly produces NMEA2000 output, then there are only three choices (ST800, ST850, DST800), and none will fit a 1.25" thruhull. It may be possible to use a non-N2K transducer connected to a converter box of some sort, but that seems a kludge way of doing it.
Edit: 4 choices counting the ultrasonic transducer.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
