SailNet Community - View Single Post - Transmission Oil Cooler set up? Questions
post #3 of Old 06-04-2018
overbored
overbored's Avatar
Re: Transmission Oil Cooler set up? Questions
the ZF trans that use an oil cooler usually have a mechanical pump on the trans and the cooler comes mounted on top of the trans. the zf 30 is a small trans so I would call the dealer and ask if it is set up to use a cooler. many of the smaller ones do not use one. the case has cooling fins and the oil is splash lubrication with no pump
"GOLD RUSH" PRINDLE 16
overbored is online now
