SailNet Community - View Single Post - Transmission Oil Cooler set up? Questions
post #5 of Old 06-04-2018
Minnewaska
Re: Transmission Oil Cooler set up? Questions
I have a ZF25, with cooler. It's simply a box that is attached to the outside of the case. Seawater flows through the box, directly from the sea strainer, then exits as it heads toward the impeller pump. I haven't look inside, but doubt it's much more than an open box. I believe they spec some sort of adhesive that conducts heat better, but think that's silly too.
I seriously wonder how much cooling it does, but they are spec'd for either the gear or displacement of the vessel. We are at the absolute top of the spec displacement for the ZF25, when in recreational use. The gear is undersized for commercial use at our tonnage. Therefore, requiring the cooler.
Jeanneau 54DS
Minnewaska is offline
