SailNet Community - View Single Post - Transmission Oil Cooler set up? Questions
post #7 of Old 06-04-2018 Thread Starter
Ocean Cruising
Re: Transmission Oil Cooler set up? Questions
Originally Posted by overbored View Post
this the one for the 25 and smaller must be the same type used on the 30 It bolts on the side of the trans
3306107001 ZF Transmission/Gear Cooler
That's perfect. My transmission has a flat side on it for something just like that. Unfortunately, that one is for the ZF25. I'm searching the internet to find one for a ZF30M, but no luck so far.
Thanks anyway, Overbored! At least now I know what I'm looking for.
And thanks to the rest of you as well. I am aware that the transmission fluid typically comes out of the transmission and goes through a heat exchanger and then re-enters the transmission, but my transmission does not seem to have any incoming and outgoing fluid connections.
Ocean Cruising is offline
