SailNet Community - View Single Post - Garmin ChartPlotter Confusion
post #10 of Old 07-26-2018
jarcher
Re: Garmin ChartPlotter Confusion
Originally Posted by CapnRon47 View Post
I purchased the 741 and I have some issues. It does not show depth from my NMEA depth sensor. Garmin claims it is because my instruments are old, I am not convinced as my old Garmin read depth fine. Other than that I am happy with my decision also. The price was right and it has all the connectivity I could possibly need (much like the 742) the display is great and it is a good upgrade from my 8 year old 5" model.
thanks,
Ron, what model NMEA depth transducer do you have? If it's an older Airmar its talking NMEA0183 at 4800 baud. It should work just fine. Make sure the Garmin communications settings are correct (which port and what baud rate). Make sure it has a common ground and is otherwise hooked up correctly.
I have a NMEA0183 depth transducer but I hooked it to my Nexus server. The data makes its way to the plotter via N2K. But I am certain this will work, unless the transducer itself is broken.
jarcher is offline
